Hi all, not being used to hi tec stuff, anybody know what N A int, that appeared on me speedo for a few seconds. when ign was switched on. thanks in advance. Tom
thats a new one on me
these are the only ones that I know about
DSB 01 Immobiliser fault: key code read but not recognised or key code not read
DSB 02 Key not present or transponder broken
DSB 03 Immobiliser fault: Antenna broken (open or short-circuit)
DSB 04 Immobiliser fault: internal controller fault
DSB 05 Fuel sensor fault
DSB 06 Air temperature sensor fault
DSB 07 Oil sensor fault DSB
DSB 08 Oil pressure fault
thank you for the info, I have made a note of those codes, since first posted the question, 14 year old grandson, no interest in motorcycles found possible answer on his phone? something to do with its time for a service. Tom.
Look closely at the code again.
On my 2016 V7 I get the code “MAInt”, except that the “M” isn’t an “M” but an inverted “U”. This code indicates that a service interval has been reached. Upon service, the bike shop should remove that code.
When I took my bike in for its first service, they forgot to remove it.
This used to happen on my 2008 V7 also.
The procedure to remove it, on the V7, is as follows:
Hold down key (A) - on the V7 there are two buttons, (A) and (B), used for altering the time, miles to clicks, F to C, etc.
Turn the ignition switch to “ON”.
Wait for the “MAInt” to disappear.
Fire up the engine, or switch off, depending on what you want to do.
The next time you switch on, the “MAInt” will have disappeared.
Let us know if it works with your Nevada.
Hi, thanks for info, worked a treat, Tom.
Good oh ! I am glad it worked.
now I Just got to change oil, filter an check other stuff, then done for winter use, roll on next spring!! more used to bigger guzzi so still on a learning curve with smaller guzzi. Tom.
