Hello,
I need to remove the flywheel on my 1950 MG Airone to get at an oil leak. I would be grateful if someone could advise the procedure, i.e. will I need a special tool? If so where can I get one ? Thanks in advance.
Hi,
Yes, you need a special tool. I bought mine online from Claudio Valenti.
I am pretty sure that the nut is on a left-hand thread, but you should check that.
