I’ve taken the front wheel out to get a new tyre fitted and when I marked the disk (I forgot until after it was out) for the direction of rotation worried myself that I might have marked it the wrong way.
It doesn’t look it, but is the wheel handed or will it fit happily either way around - provided I get the arrows on the tyre the right way when I re fit it
According to the manual, the front tyre should be fitted with the tyre rotation the wrong way round. I have no idea why this is, so maybe someone with more knowledge could assist!
From that topic (strangely I had to log on again to access it! Edit: and again to add this!!):
So, only IF tyre going on the front is meant for a rear, or maybe a 'universal'. But as Ian says nowadays they're either specifically a front or a rear, in which case the arrow is in the direction of normal rotation, for either, OR if a 'universal' will probably have two arrows, on opposite sidewalls, one way for rear, the other the opposite way for front. Each arrow will be clearly labelled 'front' or 'rear'. I guess in the early days we didn't have 'front tyres' per se, hence what the manual says. HTH (?)
