adjusting tickover on a california 1100i
Can the tickover on a california 1100i be adjusted by us mere mortals, or do you have to get the local Guzzi garage to do it for you. gramps2012-04-24 16:55:35
Yes you can
ok, how do i adjust the tickover?rolftrucker.
Well on mine,in the middle of the throttle bodies where the cable are there where two little grub screws on stops.Just wound it in a bit.
Thanks for that, will try it.Mike.
Don’t fink thats what they are for, could be wrong tho. why do you need to adjust it. if its too fast/slow something is wrong.
