italianmotor:
The Agostini breather as mentioned above is a nice little unit and good compromise between declutter and function. I’ll be using it on my Le Mans 2 special. I also wanted to not have to use rocker breather lines as I’m using early loop rocker covers, but think as Mike says best not to detour too much away from how it’s all meant to work, so I’ll probably tap’ em and add breather tubes…
Ah - I’ve going with those covers also & not thought of the absence of breathers. If you do tap, could you post photo of solution? Wonder how loop engines breathed?
Forgot I posted this up on WildGuzzi a couple of years back: I may try without breather tubes at the beginning and see how it goes: link.
That’s assuming I ever get the bike built of course…italianmotor2014-06-30 16:04:13
