I am having a bit of a problem with my 1000s and I think another opinion or two would help. I’ll give you the whole story so far.
Had to go a message this morning and took the 1000s, the bike ran great until starting on the motorway home which would have been about 15 miles into my journey.
It seemed to lose power and then pick up a wee bit, like it needed to go onto reserve, I put it onto reserve and it did pick up a bit, so I headed for petrol.
It started ok after getting petrol but a couple of miles from home it started losing power again quite dramatically, also I thought I heard some noises from underneath the tank / front of engine area.
It started to conk out whilst going up a hill and I noticed a fair bit of light smoke coming from both exhausts, (there is a collector/crossover box on bike), anyway got it home and it was reluctant to start, if it did there was a good bit of white smoke and the occasional spit back through pipes; also I noticed some of the same smoke coming out of the airbox, and one of the cylinders when I took the plugs out.
I took out the plugs and they were starting to go black , not too wet, so I changed them for another pair, tried to start it and it was very difficult, it did run eventually and smoked quite a bit but it wouldn’t react to the throttle and died in a couple of seconds, I then took the new plugs out and they were very wet with petrol.
I tried for a spark holding the plugs to the heads and got a spark on both sides, not brilliant though, so I tried another set of plugs and the spark was much the same, also tried opening the points , again got a spark from both.
For some reason I seem to be leaning towards possible ignition side problem rather than carbs, seeing as I am getting wet plugs, but then again, I am also getting a spark from 3 different sets of plugs.
Could it be the condensors?
I am also going to check the points gap, timing, valve clearances etc.
In a nutshell , it’s very difficult to fire up, won’t idle and dies quickly, won’t react to throttle, getting spark on both sides but wondering if the spark could be better.
Has anyone else experienced similar problems, or have an idea of what it could be causing it and also a cure!!!
Any help would be gratefully appreciated, no matter how small as I’m meant to be heading up the west coast of Scotland on Wednesday.
Thanks in anticipation
Robert
