BREVA 1100 ABS BRAKE PROBLEM
HAS ANYBODY COME ACROSS THIS PROBLEM
2005 BREVA 1100 WITH ABS FITTED HAD THE BIKE FOR FIVE YEARS DONE 40000 MILES PLUS
TOOK THE BIKE IN FOR A SERVICE AND TO HAVE THE BATTERY CHANGED AS BATTERY WINGAS GETTING A LITTLE
TIRED.
ON RECOLLECTING THE BIKE AFTER HAVING JOBS DONE AFTER A COUPLE OF MILES ABS LIGHT CAME ON
RETURNED BIKE TO GARAGE AND MECHANIC WENT THROUGH THE RESETTING PROCEDURE AS PER MANUAL
BUT TO NO AVAIL.THEY THEN REMOVED AND CLEANED THE ABS CONTACTS ON BOTH WHEELS. STILL NOTHING
THEY SUGGESTED THAT IT COULD BE THE DASH ABS SWITCH SO THEY REPLACED THAT STILL NOTHING LIGHT STILL ON.
ANY IDEAS?
HELP!
By the sounds of it It most likely means wheel speed sensor has failed. But could also just mean gap is wrong between the toothed ring or whatever it is and the pick-up of the sensor.
Thanks Mike will try this and let you no.
Regards Austin .
