Breva 1100 Front Fork Disassembly?
Hello All,
I have decided it is time to get the front forks of my Breva repainted as the paint is bubbling up with corrosion underneath.
Can anyone advise how to disassemble the fork?
On others I have done the fork leg is used like a slide hammer to drive out the seals and bearing collars. Is it the same for the Breva?
Any advice much appreciated.
Stop press:
Job all done. Not much force required, just a little jiggling as you pull the fork from the slider. Now I’m having trouble getting the old seals out!djpockets2013-05-19 22:45:41
