I need to replace the spring washers on one of my discs, Gutsibits calla the Belleville washers and states you need 10 per disc. My bike has onl eve had 5 on each disc, on the inside.
Question - is it 5 or 10, and if it is ten where do the other ive go ?
avw used them before on a American vibrating pump and that stated 2 each bolt and it showed then back to back so first one goes on the bolt with the small taper against the disc then the second one the other way so it looks like a flyingsaucer then the nut
to be honest I prefer the Nordic loc type (two serated washer togetherwith like teeth in middle)
