I have noticed that lately, following the winter lay up, when i pull the clutch lever in ( particularly from cold ) i get a tinny rattling sound from the gearbox area. It is still there when the bike reaches full temp but is not as noticeable. With the clutch lever released all is perfectly quiet and normal
Now normally, on most engines if a clutch thrust bearing is on its way out, it is usually quiet when under load ie the clutch lever/pedal has been depressed and rattles when it is not under load.
The bike has done 11k and the clutch works normally, transmits drive perfectly and all gears select smoothly and quietly so any idea what the noise is.
I had to look up Saga Louts. Well I never! Â Â [/QUOTE]
The definition is correct, however Sue and I find that Crack Cocaine is working out cheaper for us than a case of Stella and a bottle of wine.
Every penny counts when you are a pensioner and Sue said the CC is a big hit with the other girls at the Womens Institute at their baking days
