Cali III 97 , no spark ,any ideas
HelloÂ
Having problems with my cali III
Not spark on either side
Battery is good
Fuses good
Bike turns over , fuel pump is working
Tried removing plug caps , still no spark
Any help greatly appreciated Â
 Â
First (easiest) job, remove sensor from flywheel housing, check and clean, usual culprit in these cases.
Hi Duffo
Thank you for advice
removed sensor , was a little oily, gave it a clean but still no spark
What would you suggest next ?
Â
There are 2 sensors,one on the right side bellow the injector on crankcase another on left on top of engine both have to work
Problem fixed, it was  the flywheel sensor ,
I’d removed the sensor on the drive shaft side first, I didn’t realise the was another at the front of the engine , this was the culprit
Just a small strand of metal buggered up my ride out to the coast today.
Thank you all for your helpÂ
Â
glad it was a cheap fix
Now where did that strand of metal come from?
