I’m looking to replace the rear shocks on the bike and the front mount for the rack goes over the upper front shock mount so can’t get them off without out removing the rack first as far as I can see
The only other mount I THINK I can see is a bolt from inside the mudguard.
This has been liberally coated with water and other “carp” for the past 19 years so I’m a bit cautious about tackling that without a good coat of thinking first !!
Tris This is a job i did job this winter and yes you need a Allan key inside the mud guard as well as the obviouse bolts. Do not ping the reflectors of and end up gluing back on no point…What shocks did you buy?
