Back’s ok now, but swinging an SDS breaker above my head is not doing my arms any good and the vibration is killing my fingers.
Cripes…
Take it steady, that man!!
But just thnk of those muscles you have built up Mr Atlas.
TNormski2013-10-14 21:21:01
I have a syringe and have tried reverse bleeding to no avail. When I bled with Ray’smaster cylinder it worked normally in a minute or two and is still ok. I need to get this house stuff out of the way before I can start again. It doesn’t help that my builder has gone awol!
Pump-up garden sprayer works the best!
THE real thing is the Master cyl Ray lent WORKED the new one doesn’t BUT it worked elsewhere the ONLY place therefore it can be is the joint master cyl to hose as Ray’s one works… try ptfe tape on the male threads if that fails no matter WHAT is said that master cyl is just not good on your system.
A syringe does the job fine and , I prefer it as it is a bit more gentle and less likely to blow fluid all over everything. What surprised me was just how little fluid is actually in the caliper -hose
MUST be a leak somewhere.
