Cylinder Re-plating
Any recommendations for good quality and accurate Nikasil re-plating? (V7 II)
I’ve contacted Langcourts in Weston (£266) and Motrac in Chester (£320). Has anyone used either of these, and any good/bad experiences?
I’m particularly keen to use somewhere that will hone the bore accurately, the tolerances are pretty tight to achieve the correct piston-cyl clearance (+/- 0.005mm on bore diameter).
Ta,
Pete.
I was pleased with the results from Langcourts.
Steve.
