Daytona fuel pump[
My Dr John Daytona has developed a problem whereby switching on the ignition does not always activate the fuel pump …though when started and running never cuts out !! …but starting up again is always a fingers crossed experience … Any ideas ??? Cheers.
I would change relays over to see if that makes a difference ( ones under rear seat ,think there the same as 1100 ) after that I would look at the big block connector under tank for any wires not looking to good ,also small connector block that sits near coils .On my sport 1100 just about every problem ive had are in these areas .
Cheers johnno …removing tank next week and will investigate.
