It is indeed for the front brake master cylinder, which Gutisbits say is a trapezoid handlebar mounted reservoir jobbie, which is all part of the switch gear, so a massive job to swap out, if I can’t get the stupid rubber seal, when the ones in there, go on the wonk…
So I was just wondering, if anyone knows where I could get the seals, don’t need the piston or the spring, I DID call Gutsibits, and the lad on the phone says I’ll have to swap out all the lever, switch gear and everything. Don’t really want to get involved
in that marlarky if I can help it…
If all else fails, and if DOES come to that, I’ve got a set of Yamaha gubbings I can use, as and WHEN I need too of course…
I had what I think (?) is the same problem with my V65 Lario that has a trapezoidal MC integrated with the RHS switchgear. I too had the conversation with Gutsibits re changing the controls and unobtainable parts.
The solution I found was to order a Brembo M/C piston kit for a piston of identical diameter. It is the shape that is unique but the diameter is common to other rebuild kits. Using fine picks, lubrication and patience I teased the seals off the new piston and put them on my existing one. Hey presto, it now seals!
I’ll put a photo up of the m/c for comparison
