Lodola chain
Hi,
I’m slowly getting a 1959 Lodola (235) together and hope someone can tell me the chain size I need. Cheers.
How thick is the sprocket?
What is the distance from tooth top to tooth top?
What is distance from centre of the sprocket?
How many teeth on each sprocket?
Thanks for the advice. I’m hoping someone will have replaced a Lodola chain and remember the size, otherwise I shall have to get measuring!
Try 1/2 x 1/4 but check by measuring.
Thanks, that gives me a starting point.
1/2 x 1/4 would be a 420 pitch.
At last I’ve sorted out my chain ( delayed through health issues) I’ve fitted a 428 size, 120 links. I now have a problem with the kickstart gear teeth ( posted in the miscellaneous section) has anyone found a solution?
