Guys I needed to remove the rhs fairing to do a little touch up as I touched the wall I the garage.
Removed the fairing and laid parts out so I knew where they went. I then got interrupted and two days later when I came to refit I was in trouble. There is a frame part see attached (I hope) that I can’t figure out where it goes. I have looked in the service manual but it doesn’t even show the part exists.
so if you can help identify where it goes I will be very gratefulÂ
 Â
