Norge headlamps
I am sure this must have been asked before but a search does not bring anything up…
I need to lower the ‘dip’ headlamps on my 09 Norge. Easy enough job - once the dash is removed. But how do I do that? I have the manual, have removed the 10 x screws securing the dash panel. But it still seems solid.
Any advice appreciated
AndyB
As I said in my PM the adjusting screws can be reached without removing anything, just turning the bars from lock to lock.If you want easier access then you can lift the inner black part of the fairing by removing the 8 screws. The dash lifts with this and you may have to disconnect the big plug on the back to lift it enough.If you do disconnect it, spray the pins with an electrical contact lubricant before reassembly, can save problems later.
