Rear suspension adjustment
Yours seem to be set at number 3 preload (out of 5 possible positions). So yes can be reduced 2 stops.
Mine look exactly the same except not black springs. I also have castellated rings at the top, but not thick like yours, more like thin plate. I don’t think they can be rotated or any kind of adjustment, I think they’re just anchors or stops for the tops of the springs. Probably can be removed if spring is compressed.
Thanks Mike. Am away for a few days so will adjust them when I’m home. Can’t wait.
I’m having a simple moment. Do you just use the ‘C’ spanner with the bike on the side stand or do you have to unweight the back end of the bike?
Hi. On the side stand is fine. They’re not fighting much weight on them unless you’re sitting on the bike :blush:
Brilliant.
Thanks.
