Hi Ed, That spare socket you have found, is a “switched live” . . . That is, a nice handy 12 volt feed, that energises, with the switching on, of the ignition . . . Earlier on this year, I searched all over the wiring on my V7II, looking for a handy place to power a “charge warning light” . . . This particular “spare” socket proved to be perfectly suitable . . . Regards, Tony
Hello again Ed, for the sake of expediency, I “snipped” the plug off the end of the wires, then used a very simple portion of white connector strip to join the two ends of my wiring. . . Any good automotive supplier will have many connectors to choose from, ( even waterproof ) . . . Hope this helps . . . Regards, Tony
Does this apply to just the V7 or is my 750 Breva likely to have one too? I’d like to fit heated grips to mine.
Guzzi surely didn’t make different wiring harnesses for both bikes as the electrics must be the same?
Tsk.
That is a genuine Tomtom supply socket.
It is, as said before, a 12 V supply that is controlled by the Ignition Switch. If you have a Tomtom with a Bike mount (like an older Rider - I don’t know about the new ones), then just plug that cable into the mount, and job done.
If you don’t like Tomtom’s you can of course chop the socket off, and attach a different connector or automotive USB plug to it. But that’s what the green thingy really is.
The bits and pieces to change it should be available from any automotive supply shop (even Halfords).
