Stelvio NTX ABS. 2010. 20,000 original miles.
I have a light rattle/rassling coming from the engine. At first it was suspected that the famous Cams etc were on their way out.
Closer inspection revealed all in good order. I wonder if they have already been changed.
I have contacted all previous service centres to gain info as to what has been done in the past, currently awating info. The book is fully stamped.
Just as a precaution the sump has been removed to inspect the Big Ends, again all fine.
Personally I suspect the rassle culprit could be the oil pump.
Any ideas boys & girls ?
Vincent
