Stelvio ECU rubber boot
Brian (web master) sent me the part number for a rubber cover for the ecu part number 883968 as he knew that i had had problems with water ingress.I ordered one a couple of weeks ago from Haywards when I booked it in for the 12000 mile service. Had it serviced today so go them to fit it at the same time it only costs £3.60 plus vat but is a pain to fit (acording to Haywards mechanic) but looks like it should solve the problem I had. also if your rear brake seems poor check to make sure the caliper is not sticking mine was and i suspect it has been like that from new, I thought it was air in the fluid as the back brake has always been poor, but now works as it shouldregards keith
