Has anyone found a rear hugger for the current model Stelvio NTX? I contacted Pyramid Plastics yesterday who confirmed that they don’t yet make one.Also, been looking at the Stelvio accessories made by Stucchi Luigi. I would be interested to know if anyone has fitted any of their Stelvio offerings and would make a positive recommendation.Thanks
Won’t the skidmarx hugger fit?
Mine is Skidmarx and works well, the only problem is that it can rub on the inside of the silencer, you need to pack the silencer off with a washer under each mounting point. I found this out too late!
The Skidmarx ones are also very close to the tyre, probably depending on which tyre is fitted, but make sure it doesn’t touch, as something touching the tyre in use is an automatic MOT failure. I was lucky, I got let off with a warning.
Me too
I think I may wait until Pyramid Plastics, or someone else, make one specifically for the NTX, although in the meantime I will check out the RG racing shock tube, which at least may give some protection to the rear spring.
