Hello,
wonder if anybody could help please?
I have a 1994 750 Strada with Saprisa generation system that will just not play the game!
Although the charging light goes out at around 3500 rpm it refused to charge the battery. I have checked continuity of the wiring, cleaned all connectors, checked continuity of the alternator, confirmed earth connections, replaced the rect/reg unit - but no joy.
Any assitance or advice would be gratefully received.
Clutching at expensive straws but has anybody got experience of the Enduralast system?
yes i had there unit on my spada never missed a beat and made a vast difference to the charging and brightness of the lamps old system really had to rev to get it in the green new system 2000 rev meter 1/2 way with all lights on brilliant but expensive also made by others but name escapes me check they are suited to your bike as mine was a 1000 cc
Can you get any test readings from the wires up from the alternator? Is it actually producing a good voltage or is the problem with the control mechanism. I assume this will be some sort of 3 phase generator, putting out AC. try multi metering across the output terminals and see if you get a voltage from any of them.
