Wanted used sump for any post 75 big block engine, the type that has the screw in filter in bottom, thank you.
Hey Roy? You mean the ‘standard’ item with screw in cartridge oil filter inside sump, or are you seeking an aftermarket type with an external screw in oil filter?
Hi Barry, I am just looking for the original type, not with external filters, I am converting my 74 loop after machining the case.
