V50 11 Steering lock
When i bought my V50 11 i did,nt get a steering lock key.The ignition key does,nt seem to work so i guess i will need to change the lock.Does anyone know how to remove the old one. Thanks
Have a look at this guide for BMW’s, they use the same lock
http://w6rec.com/duane/bmw/lock/index.htm
Hi
I drilled mine out. Very soft metal so ordinary battery drill worked fine. Fitted a new one from Gutsibits. Loctited the pin for the cover back in.
Steve.
Yes I used exactly the technique shown on Don-Spada’s link above on my T3 (sme lock). Position of the drilled hole is critical as it describes. Worked out fine.
Thanks to every one for there help with my steering lock problem. Robert.
