Wiring and bulb is fine. Problem will be with the switch or the trigger for it. Couple of questions;
. Does the switch locate anything important in the gearbox? As in, can I be turning it and shifting gears with the switch out?
. Does the switch make the circuit when it is compressed or when it is extended?
The switch sits in a groove for neutral thus making the circuit when extended. When switch is removed it won`t make any difference what you do with the bike even run it if you can plug the hole with a short bolt.
CHRIS P
Great information thanks. Means I can go fool with relative impunity. Maybe another couple of washers under the switch is all I need.
