V50 III Front wheel spacer
My rebuild is nearly complete.
The box of bits is nearly empty. Sadly it does not contain the spacer that hold the front wheel tightly between the forks, unless you are going to tell me that 1cm of play is standard Moto Guzzi handling. The missing item is described as Part 12 reference GU61616330 - also noted as no longer manufacturered!
Can anyone measure this part and let me know the specification for what I will have to have made?
The electrics need to be connnected and I expect the coil/regulator/rectifier etc will all need to be replaced (storing them in a damp box for 10 years is not peak protection I guess.) Any suggestions on set up, where to start etc. I am considering making a new loom from scratch. Does anyonein UK sell such an item?
Looking forward to Spring rides.
Derek
I have a mk II, but it does look like that might be more specifically for the mk III.
