Is there a torque setting for the small spindle/axle pinch bolts (at the bottom of the fork legs) please?
I’ve read not to over tighten them but can’t find any guidance on how tight they should be.
ta
stuart
ta
stuart
I can’t find any figure either but Guzziology mentions many cases of cracked fork legs caused by over-tightening. It says ‘There’s nothing to be gained by over-tightening’.
Just nip it up so it ain’t gonna come loose, Rarely use a torque wrench myself, just use common sense. it might be an idea to put a spot of Loctite on it as it isn’t one you want to come undone and can’t get a Nyloc nut on it.
I’ve busted one before, I put it down to being over zealous cleaning out the powder coat I’d just had done and increasing the clearance too much.
According to the workshop manual for the V50 / V35 the ‘screws, fork leg to wheel spindle’ on the front suspension should be at 32 ft/lbs (4.5kg/m).
