1000 sp fairing
Hi all need the correct bracket/mounting for lower front of fairing can’t seem to find anything at Guzzibits.
I have some brackets but I want to keep them.
Happy to measure them up for you to make/get some made, if you get desperate. If you get really desperate I’ll make you some but that may take a little while.
Andrew
I think these are what you are talking
about
Hi Andrew I may have described the wrong brackets, the one I’m looking for is the central one that locates the front of fairing to lower yoke,I have a bit of a bodge there at the moment many thanks for your offer. Roy
No probs.
So to be a clear, its the small L shaped bracket that attaches bottom of handlebar fairing to yoke. I dont think I have one but Ill have a look.
Andrew
Cheers Andrew,the bracket thats on at the moment looks homemade so wasn’t sure what the original looks like,jf you have some measurements of an original one will make a better one.
Roy.
This is the stock bracket. Simple L shape with welded nut at bottom to take fairing screw and slot on upright through which a bolt holds it to threaded hole in front of yoke.
