I can’t ride my sport for any distance, it’s just too bloody uncomfortable.
So, the plan is to put a pair of handle bars on and change the style of fairing and so on.
I’ve found someone to make me a top yoke with handle bar clamps and an ignition switch mounting for £150.
Just wondered if there was anything that would do the job from another Guzzi that I could get from Reboot.
Any experts out there?
Thx
Ray
Ray, is it not possible to drill your existing yoke and fit risers?
I drilled my top yoke on my V11. The yoke has the bosses cast in them ready for drilling and bar mounts. See
https://m.facebook.com/story.php?story_fbid=1638921176160283&id=100001272488994
I needed longer fr brake hose and clutch hose, throttle cable and high idle cable (choke).
I want to be able to return it to stock.
I could just get another one and as you say fit risers.
You could drill and tap the holes for risers and if you wanted to return it to stock just blank the holes with allen key grub screws or pan head bolts. Pan heads would look worse but grub screws would need loctite to stop them rattling out. Or even use plastic bungs! https://www.ebay.co.uk/i/221966702893?chn=ps&dispItem=1&adgroupid=43978108057&rlsatarget=pla-351961674193&abcId=1128956&adtype=pla&merchantid=113800564&poi=&googleloc=9045040&device=c&campaignid=856935089&crdt=0
If you want to totally return it to stock then a spare yoke is the answer, try reboot or gusibits?
Best of luck Chris
