1200 Sport Engine Breather
Has anyone had any experience of blocked or restricted engine breather or any breather mods? The timing position sensor weeps oil despite renewing the o ring and there is a very slight weep from the main bearing seal. Cylinder compressions are good, but I wonder if the crankcase is getting pressurised a bit.
Constructive suggestions welcome.
most of the breather pipes go into the plastic box that sits in front of the air filter case, so I would start to look there first and work back from there, one of the pipes does get trapped to an extent so that it is flattened a bit if you are not careful.
out of interest what pressure readings are you getting?
