Just noticed on inspection that the Oil cooler on my 1200 Sport 2v can move slightly when you touch it (only about 2mm). Positioning seems O.K & bolted correctly . Does my Oil cooler need adjusting & re-positioning or are others the same .
If Sport owners could check to confirm, I will make necessary adjustments.
