1200 Stelvio Brembo Clutch and Brake Seals
Hi all, I am wanting to replace all the piston rubber seals on the master cylinders, brake callipers and clutch slave cylinder on my 1200 Stelvio. I have not been able to find replacement “kits” and wondered if others had had any luck in sourcing seal kits or piston and seal kits. I realise that I may have to use “ aftermarket” rather than genuine Brembo parts. Any help, assistance or advice would be welcomed. Many thanks, Phil
Depending on which slave piston size you’ve got, this may be of use
Thanks Brian. This looks a useful site. Cheers Phil
