1200 sport,
Will be off to europe shortly, what position should the headlight deflectors be stuck onto the headlight?
The stickers I bought only have car info, done a bit of research with inconclusive results,
Cheers Phil
1200 sport,
Cheers Phil
Shine your headlight at a wall then cover part of it with card and watch the effect on the beam. As long as you are not shining high on the left you should be ok. My old Tonti headlight I used to mask bottom right to stop top left beam, not sure with the Stelvio, I think I must have masked it, probably as I have suggested by trial and error!
will give it a go
I would love to comment, but I have never put a deflector on my sport in all the years I have been abroad. I thought it was level both sides - I’m going to have to check (sheepishly) ![]()
Getting dark here now, just been out and checked the pattern… Flat , stashed the deflectors under the seat, thanks for the info ![]()
