Ok new to this forum so bare with me on either wrong place for post or maybe not following guidelines. Having problems starting my Cali jackal, what’s happening is it will usually start first go but if I have to start it to three times during day there is just a click. Have read in various forums that this a common fault with these …something about starter motor not getting enough power and having to share this with various other components on bike like lights on start up etc. Also read that it’s possible to have a dedicated cable direct to starter motor ?? Can anyone shine some light on this or experienced this themselves.
Dnicol
This is a common fault and can be cured by making a wiring alteration. The original post was here http://www.motoguzziclub.co.uk/phpbbforum/viewtopic.php?f=43&t=18404 but unfortunately Brain has moved the diagrams. If you need further info please just ask.
I moved your post from small block to big block section of the tech area.
Best wishes Chris
Thanks Chris
Some discussion and pictures here too.
http://www.guzzitech.com/forums/threads/modern-no-start-issue-solution.4908/
HTH
