Hi, Anyone know how to modify the wiring loom to add hazard lights. I appreciate I’ll need an extra switch, flasher unit etc. A wiring diagram would be really useful.
Thanks, Noel. ![]()
I’d be interested in this for my V7 too.
You would have to use the fuse for the park lights or direct from the battery (with in line fuse) as you will need the hazard lights with the ignition off. They are easy enough to wire using wires from the flasher unit and indicator and indicator warning dash lights both sides. The dash lights are not essential but they remind you if you pull away and have left them on.
I have wiring diagrams of earlier models with hazard lights, see top of thread here
Best wishes Chris
Scura wiring diagram from V11 lemans.com -
Looks like can add a 2-pole changeover switch, to change between indicator switch and flasher unit directly, on some of the older models the flasher unit was connected to battery through fuse #5, so the whole circuit was ‘permanently live’.
