Hi all, this is a long shot, but does anyone know the standard clutch push rod length for a 2006 750 Breva? Many thanks, Phil
Hi Phil
Looks as though its used on a few models so you may be able to cross reference it
AF1 Racing. OEM Moto Guzzi Clutch Engagement Rod - GU20085720
or maybe this list
Thanks, that part number is correct. What I really want to do is check if the rod I have is the correct length. Does anyone know the length of the rod so o can check mine? Thanks Phil
Gonna check over the weekend in my garage, have couple of them to hand, but need to get there…
Thanks Adamigo? I look forward to the results. Cheers Phil
Hi Adamigo, please don’t forget to check through your parts in the garage and see if you have a clutch push you can measure and let me know the length. Thanks in advance, Phil
OK, found just one, but I am pretty sure they are all the same. A rod contains of thicker and thinner part. Thicker one is 141mmlong, thinner is 86mm “plus”, what together gives us 227. What is your problem . Did you run out of adjustment on both ends of your clutch cable? There’s another point, with much more range to use.
Thanks for the info Adamigo, much appreciated. Cheers Phil
