Hi all, the clutch on my Norge was getting very noisy so I decided to bite the bullet and change it. I replaced the two friction discs and the intermediate disc as well as the gearbox drive centre boss.
After a few goes operating the clutch the lever went solid. Stripped it down again today to find the end of the pushrod mushroomed over and the release bearing destroyed. The slave cylinder piston was bottomed out, hence the solid lever.
Could this be to do with the pushrod length I have been reading about.
Any thoughts or if someone can explain how to check the pushrod length would be much appreciated. I have full workshop facilities so would be able to manufacture the tool if anyone has drawings.
Thanks for looking.
Guzziology is good for this sort of thing if you have access to a copy.
Hi Mhirst. I have drawn up the clutch pushrod length checking tool. If you e mail me I’ll forward the drawing. I think you can find my mail address via this message. Cheers Phil
