2019 V7 750 Fuel injection / ECU / problem
Hi Help please !
I have just fitted a 2019 V7 engine into a light kit car but now need to wire the ECU and having big problems - don’t think this will work in a car and I’m wondering if I need a stand alone ecu -pany suggestions? would prefer to do away with the fuel injection and go carbs with a more simple set up and would look more suited to this 1950s special - has anyone converted a V7 engine to run on carbs with a simple ignition? or if anyone is up for a swap of all my throttle body/inlet / ecu all complete / have all plugs but no loom for carb set up thanks any help appreciated Lawrence
Ps Hi all - Has any of you ditched the fuel injection on a V7mk3 and converted to carbs I do have a Weber 40dcoe could run on rubber mounts love these carbs - and run a simple ignition, ? Really don’t want to give up , so looking for inlet manifolds that would fit a V7 ? Thanks Lawrence
Update
Iv now fitted a pair of Dellorto PHBH carburettors but still in a muddle - l just want a ignition system now to run this engine does anyone know if this is possible if so what did you use or have I just got to abort the whole thing any help appreciated thanks :folded_hands:
