I’m taking delivery in a week of the above and want to fit (probably Oxford) heated grips , the wiring to connect is behind a panel below the headstock on the RHS, just wondering if this a tank off exercise or can the panel be removed with the tank in situ ?
I’ve done it on a 19 plate TT and you can get away with just lifting it up a bit. There is a video on YouTube but cannot remember who.
How did you know which wire was live and which was earth on the Oxford grips ?
According to the instructions click here the red wire is +ve and the black wire is -ve.
There are a few video demonstrations on U tube, just search the interweb.
I lifted the tank to try to make it as tidy as possible (and because i have frankly enormous hands
I removed the tank to fit a new tps/heated grip unit. much easier to route the cables with it out of the way.
Did mine in situ took about 50 minutes hardest bit was reducing the throttle tube diameter
Yes that’s true, I forgot about that.
I did it the other way round.
Increased the Oxford grip’s inside diameter by using a half round wood file.
I was a bit worried about touching the wiring in the grips so i went for the twistgrip too
