Yes this is why I had to attach a gauge to the pump for the Marzochis (however you spell them )
The volume was well tiny, try to put a gauge on, PFFFWST!!! All gone
Yep, that why I put in over 1 bar, then adjusted down. There was no PFFFWST when I put the guage on to start with. The guage I used has no flexi pipe and fits direct to the valve reducing air presure loss to a minimum. Your right, it isnt a lot of air but it makes a difference and is worth doing.
this may be of some interest
The Targa handbook specifies 1 bar presure which is equal to 14.503 psi. The psi quoted for the 850 T5 seems alarmingly high
+1.
Sounds like that article is about forks twisting sideways. Nuffink to do with the springing
