Hi All,
I realise that this question has been asked before, but there doesn’t seem to a good reference point, so here goes….
Does anyone have a definitive set of torque settings for the 750T/V65/V50 range of bikes?
I have all of the workshop manuals and addenda, Guzziology (latest), the documents provided by Greg Bender and co in the US, and have made extensive web research, but I still cant find any authoritative list. I have the front end off of the 750T at present, in order to replace the fork stanchions and fork seals, but I cant even find a figure for tightening the brake callipers!
When I disassembled the front end the callipers were only done up to around 10Nm, which I found quite worrying to be honest. Surely the figure should higher than that?
For interest, here are my amassed settings that I have either measured on undoing, taken from workshop manuals, or found in other places. One or two might be reasoned guesses, but I’d be very glad of any feedback in the form of more correct figures:
Fork brace 5mm Allen key 10Nm, 4x 10mm o-rings above and 4x below the 4 steel inserts
Air pressure balancing hose at fork tops, 11mm spanner, finger tight with small spanner.
Fork cap nut 30mm socket, 70Nm
Top yoke to fork leg 8mm Allen, 35Nm (maybe 40?)
Bottom yoke to fork leg 17mm socket, 35Nm (maybe 40?)
Headlamp bracket to fork leg, 6mm Allen key, 10Nm
- mounted 30mm above lower yoke “chrome” trim piece
Front axle clamp bolt, 1 per leg 8mm Allen - 40Nm
Oil drain bolt, two alloy washers, 5mm Allen, 10Nm
Damper securing bolt, with steel washer and o-ring; base of the fork, 8mm Allen, very very tight, maybe 90Nm. Replaced at 50Nm.
Front wheel axle nut 24mm socket, 80Nm.
Front brake calliper mounting bolts, 22 Nm.
Cheers, Bob
