Hi I put a copy of yam-Guzzi wiring in frequently asked qns
Hidden Topics Active Topics Memberlist Calendar Search Help
Private Messenger Settings Logout [guzzibear]
Frequently Asked Questions
Moto Guzzi Club GB Forum : Technical : Frequently Asked Questions
Topic: Replacement switchgear wiring
< id=PD =chgOrder(this) name=PD> < ed value=1>Oldest Post First < value=0>Newest Post First
Author
Message
guzzibear
Moderator Group
Online Status: Online
Posted: 19 Aug 2011 at 12:39
this is from my notes:
From my notes the Yam wiring is as follows:-
Horn= Pink
Earth = black
Right turn =Dark Green
Turn common = Brown/white
Left turn = Dark Brown
High beam = Yellow
Flash = red/yellow
Dip = light Green
Light common = Blue/Black
On My G V1000 the Guzzi wires are:
Horn= white/black
earth=blk
right turn=grey/red
turn comm=brown with a tag on it
Left turn=green /black
High beam=Greyor slate
flash=grey/black
Dip=Light green
light common=blue/black
I have a Triumph switch that is as follows
horn= Black with 2 grey trace
earth=Brown/black with 2 grey trace
right turn=light blue 2 grey trace
turn comm=grey 2slate trace
Left turn=orange
High beam=blue with slate tracex2 these must be joined as org had twin headlamps
Flash= Red/Black
Dip=white Grey
Comm Light =Blue white
i hope this helps
Ken
I have copied NW on this but I do NOT have the lights on off on the left it has been transposed to the right hand bars so those wires you will have to figure out there is a web site with alt switchgear wiring on it it may be carl allisons site but not sure if i find out any more i will let you know.
You can test functions by using a meter if you get the comm turn the left and right will be apparrent. you can do the same with main and dip and flash
The dodgy one is the horn as it will blow a fuse if you get it wrong. lol
You can call me if yu have proba BBB has my Number
Edited by guzzibear - 10 Aug 2008 at 18:41
“The older I get, the better I was!”
Leics
IP: 217.43.134.166
guzzibear2011-12-09 11:08:10
