ABS Brake & Clutch Bleeding
I am well practiced at changing the brake fluid on my bikes, but my Norge 1200 has ABS. Does this require any special technique or do I just bleed it through as with a non-ABS bike? Also, can anyone point me to the bleed nipple for the clutch slave cylinder? Sorry for the dumb questions but I’m a Guzzi rookie.
I can’t help with the ABS bleeding but there should be a hydraulic hose clipped to the top of the battery cover.
That’s the bleed line for the clutch - at least it is if your Norge is the same as my Breva 1100
Thanks Tris, yes there is a remote hose under the seat. I wrongly assumed that was for re-gassing the rear shock. Live and learn!
No problem - glad I could help
