Cheers guys for all the info.
Picking up on some of the points made:
I have details for Mel however he’s in Glasgow and I’m in Aberdeen, bit of a hike between the two.
The local dealer, is a Guzzi dealer no more, I assume they still have the diagnostic equipment for Guzzi’s, but since they couldn’t fix the problem before can’t see the point of taking it back to them.
On saying that they didn’t manage to stop the bike from initially settling at 2000 rpm before dropping to 1000 rpm at idle, but they did resolve the problem when rolling off the throttle, the revs did immediately drop to 1000 rpm, however the problem of initally settling to 2000 rpm at roll off then dropping to 1000 rpm has now returned.
Further, the drain tube from the air box with the plug on the end, small amounts of water collect in it, the manual does say to clear the tube every few months, is it normal for water to drain from the air box, could this be an indication to the rev problem as I never had any water drain from the Griso’s air box.
Also, given the fact there is no ‘dealer’ in the north of Scotland now, and I’ve no problems with working on the bike, would diagnotic software such as Ducatidiag help me in fixing engine management problems myself.
Taking on the comment that the replacement lambda sensor could be faulty, I’ve sent away for another one.
As Brian said the connection is behind the starter motor, it seems a bugger to get to, has the motor got to be removed.
Cheers,
Keith
