Hi, I’ve found a crack in the bottom of one fork leg and was wondering if the forks from any other guzzi will fit.
Look up the part number for the damaged item that you are looking to replace and then do a Google search for that part number by searching for Guzzi and the part number.
GU03490611 is the part number for a complete right fork leg assembly and it looks like it is the same as an 1100 California, but do some more research on that before taking my word for it.
Here is a link to the parts book
Could you get it welded?
Thanks Don, i will check this out
I was considering that, just got to find somewhere local that can do it
Hi!
I have a set of Cali EV forks i think will fit. I will check when im back in the workshop on monday.
Regards, Nik
Thanks Nik, where abouts are you?
Sorry, wrong Caliper Mounting other wise they would be ok!
My workshop is in Tangmere, near Chichester.
Regards, Nik
