Having thoroughly washed and cleaned my Bellagio I now have a non working speedo with the’Service’ warning and red triangle showing on the clock. I always try to avoid wetting the the clock assembly but could it be a waterlogged sensor somewhere? Any ideas please. Thanks
Could be the speedo sensor on the rear drive box they were known for letting in water later sensors were better sealed I would look at that first
Regards keith
Rediculous, what happens if it rains?
It doesn’t rain in Italy
You obviously weren’t in Mandello for the 95th then!?
Nor the 90th!
…and so ends the weather forecast
The bike wont start the next day, you get dragged home in a van and spend the next 6 months trying to understand what happened until you finally work out that a wet speedo sensor can kill a Breva 1100
At least that’s what happened to me!
