Ok folks…How the hell do you torque up the nut on the bevel box pinion bearings? Whats the best way to hold the box? I can get a deep reach socket on it but finding it hard to hold the bevel box(have it on the wheel with axle)
If you look in the o/e workshop manual it shows the correct tools for the job.
To hold the splined shaft you can make the tool from a old female coupling cut down to about 20mm long then weld a piece of flat bar ( 5 or 6mm x 20mm will do nicely)to it to make a ring type spanner.This makes a tool just like o/e.
To tighten the nut you need to make a tool from a 1/2" socket cut off the top( use a angle grinder) were the 1/2" square is so you end up with a straight through socket then weld a flat bar( size as above) on to it to make a ring spanner.This makes a tool just like o/e.
You cannot torqe the nut up with a torque wrench even with a o/e tool so guzzi must use a different set up at the factory or maybe not.
OR you could bodge it just as i have seen done both on this nut and the gearbox output nut and clamp the splined shaft in a vice / mole grips/pipe wrench. NONE of which have managed to tighten the nut up tightly. I have also seen the cold chisel methord as well
ralph2012-11-06 10:22:26
Have just reread my posting,and obviously got mixed up with the gearbox ouput shaft nut. Blame it on my age !You can tighten up the pinion nut with a spanner or a crows foot and torque wrench,but realy do need the tool to hold the spline.
I think I held the output spline in a set of soft aluminium jaws in my bench vice.
As per this?
[QUOTE=Mike H] As per this?
Â
 [/QUOTE]
Spot on .
Thanks guys. I managed to make a pinion holding tool by welding an old UJ and 1/4’’ drive, and tightening the nut with a ring spanner.
